But this won't create a parametric link - if I change the hole thread from 12 to 14mm I want the stud thread to change automatically as with all other top down dimension relations? Is there an identifier for a Thread feature or a threaded hole which can be included in a dimension equation? Cheers
Sean,
select Inch Die
instead of Inch Tap
If you would like better help just attach your .SLDPRT file to you forum post and many here will be pleased to advise you.
