1 Reply Latest reply on Mar 19, 2018 10:37 AM by Harold Black
    Selecting boundary lines for a trim inside operation
    Harold Black
      I have a spline where I need to trim all the vertical lines below it. I figure the easiest approach would be to create a horizontal line and use the spline and horizontal line as boundary entities for "Trim away inside". How would I loop through all my sketch segments to select the boundary entities and then the entities to trim? For the spline I can search for swSketchSeg.GetType and see if it is swSketchSpline, but this sort of comparison would not work for the straight lines. Any help would be appreciated. I've attached a screenshot of what my code produces thus far. The values for minEl and maxEl will have to be changed depending on what your min and max y values are for your spline. The vertical lines should extend past the spline above and below. Change the number of divisions according to the length of your spline.
          Dim swApp                       As SldWorks.SldWorks
          Dim swModel                     As SldWorks.ModelDoc2
          Dim swSelMgr                    As SldWorks.SelectionMgr
          Dim swSketchMgr                 As SldWorks.SketchManager
          Dim swSketchSeg                 As SldWorks.SketchSegment
          Dim swSketch                    As SldWorks.Sketch
          Dim swCurve                     As SldWorks.Curve
          Dim nStartParam                 As Double
          Dim nEndParam                   As Double
          Dim bIsClosed                   As Boolean
          Dim bIsPeriodic                 As Boolean
          Dim vStart                      As Variant
          Dim vEnd                        As Variant
          Dim LStart                      As Variant
          Dim LEnd                        As Variant
          Dim vSegs                       As Variant
          Dim Seg                         As Variant
          Dim bRet                        As Boolean
          Dim minEl As Double
          Dim maxEl As Double
          Dim divisions As Integer
          Dim spacing As Double
          Dim myFeature As SldWorks.Feature
          Dim boolstatus As Boolean
          Dim xstart As Double
          Dim xend As Double
          Set swModel = swApp.ActiveDoc
          Set swSketchSeg = swSelMgr.GetSelectedObject5(1)
          Set swCurve = swSketchSeg.GetCurve
          Set swSketchMgr = swModel.SketchManager
          Set swSketch = swModel.SketchManager.ActiveSketch
          bRet = swCurve.GetEndParams(nStartParam, nEndParam, bIsClosed, bIsPeriodic)
          Debug.Assert bRet
          minEl = -10 / 1000
          maxEl = 60 / 1000
          divisions = 7
          vStart = swCurve.Evaluate(nStartParam)
          vEnd = swCurve.Evaluate(nEndParam)
          spacing = (Abs(vStart(0) - vEnd(0))) / divisions
          xstart = vStart(0) + spacing / 2
          xend = vEnd(0)
          swModel.CreateLineVB xstart - spacing / 2, minEl, 0#, xend, minEl, 0#
          'Create first centerline and pattern it
          swModel.CreateLineVB xstart, minEl, 0#, xstart, maxEl, 0#
          boolstatus = swSketchMgr.CreateLinearSketchStepAndRepeat(divisions, 1, spacing, 0.01, 0, 1.5707963267949, "", False, False, False, False, False)
          'Select all but a SPLINE sketch segment and color it red
          vSegs = swSketch.GetSketchSegments
          For Each Seg In vSegs
              Set swSketchSeg = Seg
              If swSketchSeg.GetType <> swSketchSPLINE Then
                  swSketchSeg.Select True
                  swSketchSeg.Color = vbRed
          Next Seg
          Debug.Print String(255, vbNewLine)
          Debug.Print spacing
          Debug.Print "  Start Pt     = (" & vStart(0) * 1000# & ", " & vStart(1) * 1000# & ", " & vStart(2) * 1000# & ") mm"
          Debug.Print "  End   Pt     = (" & vEnd(0) * 1000# & ", " & vEnd(1) * 1000# & ", " & vEnd(2) * 1000# & ") mm"
