Moving cuts when depth of part is changed.
Question asked by Jeff Westbrook on Mar 19, 2018
Latest reply on Mar 28, 2018 by Kevin Pymm
I have a small assembly, that I am setting up for our users to be able to easily edit, based on the depth of the body we are using. Currently I have the rivet holes set up and defined for the largest assembly. When the part is shrunk down to the next size the holes tend to "move" up instead of staying where I would think they should be.  I am not sure how to fix this, or if it is even possible to do so. Hole one is the assembly as it should look. Hole two is when the assembly is shrunk down to the next size.
