I met some problem with annotations. Can you help me?
Assembly (SWX 18) is attached
Hi Igor,
You need to move the annotations to Notes Area instead of Front*.
Thank you, OK, sometimes annotations disappear sometimes everything is OK even without 2D Notes Area.
I think it is a bug, but fortunately, I found the workaround for it.
It is necessary to select an edge or visible face or surface for note leader.
Selecting edge for note leader is the better choice because it works in any viewing direction.
