Howdy! I'm a solid work rookie and would like to know can i
get some points datum in Excel into Solidworks.
I measured some points position with a laser tracker. Now I want to analyze the lines and planes formed by these points. How can I get these data into Solidworks and analyze them? Or Solidworks is not the right tool to do this kind of analysis?
Tips for working with this tool:
Open an existing curve file. Click Browse and navigate to a curve file to open. You can open .sldcrv files or .txt files that use the same format as .sldcrv files. You can also create 3D curves in Microsoft Excel for example, save them as .txt files, then open them in SolidWorks. Create a file containing coordinate values for curve points using a text editor or worksheet application. The file format must be a three-column, tab, or space-delimited list of only X, Y, and Z coordinates. Do not include any column headings, such as X, Y, and Z or other extraneous data
