please i need to create a 3d sketch array, but the sketch not the operation, is this posible?
Rhonald Fuentes wrote:
please i need to create a 3d sketch array, but the sketch not the operation, is this possible?
Probably, but as Tom dunn said, it's hard to tell from your description.
How can I make a circular array in 3d sketch?
How to pattern a 3D-sketch helix ?
3D Sketch Pattern for weldment profile
Patterns are impossible inside a 3d sketch.
However, you can create a surface body from your first 3d sketch and then pattern that.
Then use the edges to either create another 3d sketch or use the edges directly.
Attached is a video that shows how one could do this (maybe not exactly the way Alex Burnett did it).
It went pretty fast.
I attached the file so you would be able to look at what I did. Essentially, I created a circular pattern to make a lot of lines in a circular array and extruded those as a surface. I then did an offset surface on the inside circle of the solid.
Then I used Intersection Curve on these surfaces and it generated a 3D sketch out of all of the intersections. (I forgot that it doesn't create a feature called intersection curve otherwise I would have noted that in my previous response)
I then did a Delete/Keep Bodies on the surfaces to delete them since I no longer need them.
Rhonald, I am sorry but the information you supplied it not enough. Can you add a picture of what your are trying to achieve?
