Is there a way to automatically populate Created by/Author (User name) in custom properties field. As same as the "SW-Last Saved by" property pulled by Property tab builder?
Thanks in advance.
Regards,
Sai
Thanks in advance.
Regards,
Sai
Here is a Macro that you can use to copy the author with use the swSumInfoAuthor to yourCustomPropertyauthor
hope this helps
Copy below this line into the macro editor
Dim swApp As Object
Dim Value As String
Dim Temp As String
Set swModel = swApp.ActiveDoc
If swModel.CustomInfo("Description") <> "" Then
'swModel.CustomInfo("yourCustomPropertyauthor") = swModel.SummaryInfo(swSumInfoAuthor)
Else
'swModel.AddCustomInfo3 "", "yourCustomPropertyauthor", swCustomInfoText, swModel.SummaryInfo(swSumInfoAuthor)
'swModel.CustomInfo("Description") = swModel.SummaryInfo(swSumInfoTitle)
Else
'swModel.AddCustomInfo3 "", "Description", swCustomInfoText, swModel.SummaryInfo(swSumInfoTitle)
If swModel.CustomInfo("swSumInfoCreateDate") <> "" Then
swModel.CustomInfo("CREATED_REVISION_DATE") = swModel.SummaryInfo(swSumInfoCreateDate)
'Debug.Print "updated CREATED_REVISION_DATE"
Else
swModel.AddCustomInfo3 "", "CREATED_REVISION_DATE", swCustomInfoText, swModel.SummaryInfo(swSumInfoCreateDate)
'Debug.Print "added CREATED_REVISION_DATE"
swModel.CustomInfo("CURRENT_REVISION_DATE") = swModel.SummaryInfo(swSumInfoSaveDate)
'Debug.Print "updated CURRENT_REVISION_DATE"
Else
swModel.AddCustomInfo3 "", "CURRENT_REVISION_DATE", swCustomInfoText, swModel.SummaryInfo(swSumInfoSaveDate)
'Debug.Print "added CURRENT_REVISION_DATE"
swModel.ForceRebuild3 (False)
swApp.SendMsgToUser "Created and last saved date written to Custom properites"
'swModel.Save
Can i use my windows username as custom property?
Best method for inserting username into Part/Drawing
set custom username instead of Environ(USERNAME)
How Do I Get The Current Windows Username
