Good Evening all,
So I have an item (i believe it is text) that is off the schematic sheet, and I can not select it or select the area. This item is causing errors and being a pain, my question is how to do i remove it? A little more history this page was part of an imported file (.dsn file from orcad), I did try adjusting sheet size and playing with grids but still can get to it. Any Ideas?
Warm Regards,
Lee Havens
Hi Lee,
Have you tried to do a 'Select All' and then do a 'Deselect Inside Area' and drawing a rectangle following the border of the page allowing the objects outside still being selected.
BR
Markus
