6 Replies Latest reply on Apr 1, 2018 11:52 PM by Prasanna Ashok
    PDF conversion
    Prasanna Ashok
      Hi All,
      I need to know any option is available to define the name when we convert PDF.
      When i open "XXXX" drawing and save as pdf, default pdf name is "XXXX".pdf
      But our customer has requested for a new format going forward.
      Convention: Drawing Name_4digitsheetnumber_2digitrevision
      1. For single sheet "XXXX" dwg, Rev-0: XXXX_0001_00
      2. For 2 sheet "XXXX" dwg, Rev 1: XXXX_0001_01   (First sheet revision is 1)
                                                             : XXXX_0002_00  (Second sheet revision is 0)
      Now we update this manually. Any option that this format can be populated when i say "File-->save as-->pdf"? For every sheet we need to create a separate pdf.
      I guess it has to drive this from the sheet title block where we have dwg no, sheet no and the revision no.
      Any macro, help or suggestion?
      Deepak Gupta
      Regards,
      Prasanna.A
