1 Reply Latest reply on Mar 15, 2018 8:14 AM by Taus Moller
    How to use API to delete and rename command tab box from vb template?
    Chiao Yang Chang
      I change the Title and Tooltip in the solidworks vb template.
      Then I get a new command tab box. (see Fig1)
      How could I delete original command tab box in this template?
      If I just want to rename the command tab box, how could I do?
      【vb template code】
      #Region "UI Methods"
          Public Sub AddCommandMgr()
              Dim cmdGroup As ICommandGroup
              If iBmp Is Nothing Then
                  iBmp = New BitmapHandler()
              Dim thisAssembly As Assembly
              Dim cmdIndex0 As Integer, cmdIndex1 As Integer
              Dim Title As String = "VB New Addin"
              Dim ToolTip As String = "VB New Addin"
              Dim docTypes() As Integer = {swDocumentTypes_e.swDocASSEMBLY, _
                                             swDocumentTypes_e.swDocDRAWING, _
                                             swDocumentTypes_e.swDocPART}
              thisAssembly = System.Reflection.Assembly.GetAssembly(Me.GetType())
              Dim cmdGroupErr As Integer = 0
              Dim ignorePrevious As Boolean = False
              Dim registryIDs As Object = Nothing
              Dim getDataResult As Boolean = iCmdMgr.GetGroupDataFromRegistry(mainCmdGroupID, registryIDs)
              Dim knownIDs As Integer() = New Integer(1) {mainItemID1, mainItemID2}
              If getDataResult Then
                  If Not CompareIDs(registryIDs, knownIDs) Then           'if the IDs don't match, reset the commandGroup
                      ignorePrevious = True
              cmdGroup = iCmdMgr.CreateCommandGroup2(mainCmdGroupID, Title, ToolTip, "", -1, ignorePrevious, cmdGroupErr)
              If cmdGroup Is Nothing Or thisAssembly Is Nothing Then
                  Throw New NullReferenceException()
              cmdGroup.LargeIconList = iBmp.CreateFileFromResourceBitmap("SwVBAddin4.ToolbarLarge.bmp", thisAssembly)
              cmdGroup.SmallIconList = iBmp.CreateFileFromResourceBitmap("SwVBAddin4.ToolbarSmall.bmp", thisAssembly)
              cmdGroup.LargeMainIcon = iBmp.CreateFileFromResourceBitmap("SwVBAddin4.MainIconLarge.bmp", thisAssembly)
              cmdGroup.SmallMainIcon = iBmp.CreateFileFromResourceBitmap("SwVBAddin4.MainIconSmall.bmp", thisAssembly)
              Dim menuToolbarOption As Integer = swCommandItemType_e.swMenuItem Or swCommandItemType_e.swToolbarItem
              cmdIndex0 = cmdGroup.AddCommandItem2("CreateCube", -1, "Create a cube", "Create cube", 0, "CreateCube", "", mainItemID1, menuToolbarOption)
              cmdIndex1 = cmdGroup.AddCommandItem2("Show PMP", -1, "Display sample property manager", "Show PMP", 2, "ShowPMP", "PMPEnable", mainItemID2, menuToolbarOption)
              cmdGroup.HasToolbar = True
              cmdGroup.HasMenu = True
              cmdGroup.Activate()
              Dim flyGroup As FlyoutGroup
              flyGroup = iCmdMgr.CreateFlyoutGroup(flyoutGroupID, "Dynamic Flyout", "Flyout Tooltip", "Flyout Hint", _
                    cmdGroup.SmallMainIcon, cmdGroup.LargeMainIcon, cmdGroup.SmallIconList, cmdGroup.LargeIconList, "FlyoutCallback", "FlyoutEnable")
              flyGroup.AddCommandItem("FlyoutCommand 1", "test", 0, "FlyoutCommandItem1", "FlyoutEnableCommandItem1")
              flyGroup.FlyoutType = swCommandFlyoutStyle_e.swCommandFlyoutStyle_Simple
              For Each docType As Integer In docTypes
                  Dim cmdTab As ICommandTab = iCmdMgr.GetCommandTab(docType, Title)
                  Dim bResult As Boolean
                  If Not cmdTab Is Nothing And Not getDataResult Or ignorePrevious Then 'if tab exists, but we have ignored the registry info, re-create the tab.  Otherwise the ids won't matchup and the tab will be blank
                      Dim res As Boolean = iCmdMgr.RemoveCommandTab(cmdTab)
                      cmdTab = Nothing
                  If cmdTab Is Nothing Then
                      cmdTab = iCmdMgr.AddCommandTab(docType, Title)
                      Dim cmdBox As CommandTabBox = cmdTab.AddCommandTabBox
                      Dim cmdIDs(3) As Integer
                      Dim TextType(3) As Integer
                      cmdIDs(0) = cmdGroup.CommandID(cmdIndex0)
                      TextType(0) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                      cmdIDs(1) = cmdGroup.CommandID(cmdIndex1)
                      TextType(1) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                      cmdIDs(2) = cmdGroup.ToolbarId
                      TextType(2) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextHorizontal
                      bResult = cmdBox.AddCommands(cmdIDs, TextType)
                      Dim cmdBox1 As CommandTabBox = cmdTab.AddCommandTabBox()
                      ReDim cmdIDs(1)
                      ReDim TextType(1)
                      cmdIDs(0) = flyGroup.CmdID
                      TextType(0) = swCommandTabButtonTextDisplay_e.swCommandTabButton_TextBelow
                      bResult = cmdBox1.AddCommands(cmdIDs, TextType)
                      cmdTab.AddSeparator(cmdBox1, cmdIDs(0))
              Next
              thisAssembly = Nothing
      [Fig1]
