I am currently trying to work running a simulation on a part but it only allows for the simulation of one body at a time. The part was created using weldment, what is the best way to combine these bodies into one so the part can be run through simulation?
I assume you are using simxpress which does not allow you to perform simulation for multibody and assembly; anyway, simply search for combine command which also can be found under direct editing tab.
