When creating a pipe routing tee with multiple configurations, what does Diameter@RunRoute refer to?
Question asked by Justin Itzkowitz on Mar 13, 2018
Latest reply on Feb 20, 2020 by Sandy Scott
I was in the process of creating a Tee with multiple configurations for my pipe routing library, but during the Design Table Check it said I need to have a column header for Diameter@RunRoute.  What does this refer to?  Is RunRoute supposed to be a sketch?  Does Diameter refer to the outer diameter of the pipe?
The way I created my Tee was with a revolve of the horizontal part, and then an extrude with several cuts to create the perpendicular end.  If RunRoute is meant to be the sketch, is that referring to the cylinder with two openings?  Here as an image of what I am referring to.
