hi all,
I''m currently working in an assy with loads of components with some repetitive parts. While drafting I had to assign layers individually and its quite tiresome to do it to all parts. Is there any method or tool to assign a layer to all repetitive components (same part name or ID) in an assy.
thanks in advance
Visweswaran
Hi Visweswaran
Here's a suggestion. First, create a new layer. Then, control select the components in the assembly tree, right click and select component line font.
Uncheck "use document defaults" and select "from selection" and choose the new layer.
