OSOrla Sørensen09/03/2018
Hi
I’m trying to simulate the air flow and the process in a dehumidifier
Regarding the pressor drop the results seems ok, but when it comes to humidity the simulation result looks strange.
Inlet: 20°C, RH 80% = 13,85g/m³
After evaporator: 11,46°C, RH 100% = 10,31g/m³
After condenser: 27,39°C, RH 52,39% = 13,81g/m³
That means that there has been on dehumidifying doing the cooling down
If I assume that the temperature is simulated correct and calculate the HR it looks like this
Inlet: 20°C, HR 80% = 13,85g/m³
After condenser: 27,39°C, RH 39,1% = 10,31g/m³
What can I have been doing wrong, or can’t Solidworks flow simulation just not simulate dehumidifying?
Thank you
Orla
