Hello
I would like to insert a column in my BOM, that would tell me whether my weldments are cut at an angle in one end, the other end or both ends, by inserting
a symbol that would look like I=/ or perhaps something else. The symbol is to tell the projectmanager, that they need to look at the drawing before ordering materials.
I have been trying out some IF OR equations with the custom properties angle1 and angle2, but I am at a loss. The angles are show in the drawings, but the BOM is also what we order materials from.
Any ideas?
This is what I have in mind.
Hi Marc,
Insert a BOM with indented cutlist shown. Select to show Angle 1 & Angle 2 in two columns. SW has it's own format for if statements that refer to custom properties or column headers. Look up equations, bom in the help file. You should be able to check if your angles are unequal to empty. That should work.
Simply hide the angle columns after.
You need a little patience. The SW Bom is awful to work with. The good news is after you have spent 2 hours to write a 10 second excel-like equations you can save out the template and start forgetting about the obnoxious experience you just went through.
No way around it, until SW coders themselves have to work with it and say "the hell with this, after a mere 2 seconds"
Elmar
