sheet metal cut under the flat pattern not visible in the drawing view on flat pattern view
Question asked by Sorin Albu on Mar 8, 2018
Latest reply on Mar 9, 2018 by Sorin Albu
I’m working to a sheet metal and I create a simple
circular notch under the Flat Pattern for identify the axis bends intersection with
the geometry unfortunately in the drawing on flat pattern view these notches didn’t
appear, usually a simple cut like that must not create problem everything what
is created under the flat pattern must appear in flat pastern view drawing,
please there is a settings, or I have problem with the Solid Works that is sp1.0
2018 version professional, thank you I appreciate. In the 3D model on flat
pattern, the cut appear and is ok. Thank you.
Sorin,
