Please don't ban me for asking too many questions. Please bear with me because Im so frustrated with it.
My goal is to compare double pipe heat exchanger heat transfer coefficient calculations and the simulation results of the said parameter,
however Im so frustrated because the calculation results and flow simulations results dont match or even come close. I think, my problem is that
what value of heat transfer coefficient from the surface plot I could compare to the calculation results to have at least closer results.
From the surface plot:
Hi Michael,
My reply may not be that of help but it clarifies simple facts.
1) You need to start going over your simulation setup to see what did you wrong. What assumptions/simplifications made you too car from reality. How do you judge if these are correct numerical results...etc.
2) People are here to help, so it's better to continue on your earlier post to let others also keep track of the case.
3) Share your model and sim setup to get more accurate and quicker response.
Good luck!
