How can I set up solidworks 2018 to automatically prompt me to pick which view I want to start with (on my drawing) , or place the standard 3 view onto my drawing?
When I had Solidworks 2016, I would perform the following to create a 2d drawing from my model:
From my model, I'd select New > make Drawing from part/assembly.
Then select my template (I have two that I use) .
Then I was prompted as to which view I wanted to place on the drawing.
I would like to set it up so I am prompted.
I know it's just a few mouse clicks to go to Insert> Drawing View > Standard 3 View then click the green check, but I've been spoiled by solidworks doing the work for me.
If you usually place the same views, add them to your template. Then SolidWorks will place them for you.
