When you create a part in the context of an assembly you have
the opportunity to save it as a separate file or as part of the
assembly (virtual component). They are usually used when someone
needs a quick mock-up of a part that they don't care about. I tend
not to use them because they are somewhat unstable.
I have been using scaffolding (sketches and layouts) for parts I
need but don't care about. Scaffolding seems to have infinite
strength and zero deflection.
The downside is that sub assemblies with scaffolding cannot be
solved as flexible.
Cheers,
I have been using scaffolding (sketches and layouts) for parts I need but don't care about. Scaffolding seems to have infinite strength and zero deflection.
The downside is that sub assemblies with scaffolding cannot be solved as flexible.
