Hi all,
Is there a technique for displaying multiple XYZ coordinates for multiple hole centres/points within the part file?
I know I can click the hole and it will display at the bottom, or use the Measure tool but this can only show one at a time.
Ideally I'd like something similar as the measure tool but displaying each hole centre separately rather than the distance between holes.
This is to show what needs engraving on a plate and which plate goes with which hole.
Thanks, Kyle
You can create a drawing, even if a temporary one, and add a hole table.
It's only X-Y to the view, but you can add other views with other hole tables, if needed.
Cheers,
Kevin
