I am trying to combine two solid bodies but it is giving me an error. I even checked if I merged when I created the part (Loft thin 2).
Hello Vorakit.. this is what is called a ZTG (zero thickness geometry) .. hold on.. I selected different bodies.. well,.. as Benjamin Modic said.. that is not touching
...but the others are ZTG.
Hey Vorakit,
There is a gap between your bodies that is not present on the other side. The coincident faces may also be part of the issue as well. Should this gap be present?
