Hi all,
I'm trying to generate a 30mm miter flange on this bent shield (18GA 304 Stainless Steel) but for some reason it wont go all the way around. At most I can get it to generate 3 edges (side and top or side and bottom including the bend) however it will never work with more than three.
This is the part in question and the flange is to go all the way around. If I select all the edges and hit okay, it gives me a little thing saying "Please select sketch segments or edges for swept flange path". Not sure what it means by this as all the edges I've selected are contiguous and normal to the sketch.
Any help is appreciated,
Zach
I met the same problem. The miter flange cannot be generated on more than 3 edges selected. If anyone can help please.
