JWJonathan Westcott04/03/2018
I have a standard SolidWorks macro that I'm trying to get to run during a PDM task but can't seem to get it to work. I keep getting the error
I've set that task to run on the computer it was launched and am running as admin so will have permissions.
I'm guessing that I've done something wrong in way I'm calling the macro after checking out the file in the vault it out in the vault.
The RunMacro2 code runs in the SolidWorks environment.
I just don't really get the VB.NET bit.
I've tried to adapt the code form this other thread https://forum.solidworks.com/thread/209804 but think I've probably just made a mess haha.
Any ideas would be very much appreciated.
Code below.
Option Explicit On
Dim swApp As Object
Dim errors As Long
Dim warnings As Long
Dim FileSystemObj As Object
Dim swModExt As SldWorks.ModelDocExtension
Dim Vault As Object
Dim vViews As Variant
Dim i As Integer
Dim boolstatus As Boolean
Dim runMacroError As Long
#If VBA7 Then
Private Declare PtrSafe Function GetLongPathName Lib "kernel32" Alias "GetLongPathNameA" (ByVal lpszShortPath As String, ByVal lpszLongPath As String, ByVal cchBuffer As Long) As Long
Private Declare PtrSafe Function LoadLibrary Lib "kernel32" Alias "LoadLibraryA" (ByVal lpLibFileName As String) As Long
Private Declare PtrSafe Function GetProcAddress Lib "kernel32" (ByVal hModule As Long, ByVal lpProcName As String) As Long
Private Declare PtrSafe Function FreeLibrary Lib "kernel32" (ByVal hLibModule As Long) As Long
Private Declare PtrSafe Function GetTempPath Lib "kernel32" Alias "GetTempPathA" (ByVal nBufferLength As Long, ByVal lpBuffer As String) As Long
#Else
Private Declare Function GetLongPathName Lib "kernel32" Alias "GetLongPathNameA" (ByVal lpszShortPath As String, ByVal lpszLongPath As String, ByVal cchBuffer As Long) As Long
Private Declare Function LoadLibrary Lib "kernel32" Alias "LoadLibraryA" (ByVal lpLibFileName As String) As Long
Private Declare Function GetProcAddress Lib "kernel32" (ByVal hModule As Long, ByVal lpProcName As String) As Long
Private Declare Function FreeLibrary Lib "kernel32" (ByVal hLibModule As Long) As Long
Private Declare Function GetTempPath Lib "kernel32" Alias "GetTempPathA" (ByVal nBufferLength As Long, ByVal lpBuffer As String) As Long
#End If
Sub RunMacro(docFileName)
    Call LoginToVault()
    Dim strCheckOutFileErrorMessage As String
    strCheckOutFileErrorMessage = CheckOutFile((docFileName))
    boolstatus = swApp.RunMacro2("D:\Prefix Custom Properties (sldprt & sldasm).swp", "Prefix", "main", swRunMacroUnloadAfterRun, runMacroError)
    swModel.Save3 swSaveAsOptions_Silent, errors, warnings
    swApp.QuitDoc swModel.GetTitle
    Dim strCheckInFileErrorMessage As String
    strCheckInFileErrorMessage = CheckInFile((docFileName))
Private Sub LoginToVault()
    On Error GoTo ErrHand
    Dim strTempVaultName As String
    Dim strVaultName As String
    strTempVaultName = "<VaultPath>"
    i = Len(strTempVaultName)
    j = InStrRev(strTempVaultName, "\")
    strVaultName = Right(strTempVaultName, i - j)
Set Vault = CreateObject("ConisioLib.EdmVault.1")
Vault.LoginAuto strVaultName, 0
Exit Sub
ErrHand:
    If Not Vault Is Nothing Then
        Dim ErrName As String
        Dim ErrDesc As String
        Vault.GetErrorString Err.Number, ErrName, ErrDesc
MsgBox "Could not open file vault." + vbLf + ErrName + vbLf + ErrDesc
'ErrorOut "Could not open file vault.", errorFilePath
    Else
        MsgBox "Error creating file vault interface."
Private Function CheckOutFile(strFileName As String) As String
    Dim folder As Object
    Dim folderPath As String
    Dim FolderPath1 As String
    folderPath = strFileName
    j = InStrRev(folderPath, "\")
    FolderPath1 = Left(folderPath, j)
Set folder = Vault.GetFolderFromPath(FolderPath1)
i = Len(strFileName)
    j = InStrRev(strFileName, "\")
    FileName = Right(strFileName, i - j)
    Dim file As Object
    Dim oNull As Object
Set file = folder.GetFile(FileName)
If file Is Nothing Then
        'MsgBox "File not found."
        Exit Function
    file.LockFile folder.ID, 0
CheckOutFile = "Successful"
    Exit Function
ErrHand:
    Dim ename As String
    Dim edesc As String
    Vault.GetErrorString Err.Number, ename, edesc
CheckOutFile = edesc
    'MsgBox ename + vbLf + edesc
End Function
Private Function CheckInFile(strFileName As String) As String
    Dim file As Object
    Dim oNull As Object
Set file = Vault.GetFileFromPath(strFileName, oNull)
        Exit Function
    file.UnlockFile 0, "The file was checked in!"
CheckInFile = "Successful"
    Exit Function
ErrHand:
    Dim ename As String
    Dim edesc As String
CheckInFile = edesc
End Function
    Set FileSystemObj = CreateObject("Scripting.FileSystemObject")
    docFileName = "<Filepath>"
    swApp.Visible = True
    RunMacro docFileName
    Exit Sub
