hello guys,,
i have problem trying to rendering turnable,..,. its not in the center as it should be,.. this only happend with 2018
i keep trying to fix it but,, it shows in preview correct but in final render,, it drift away from the center
Does it happen to the other models or just this one?
to all even for sample
i did find a temporary fix i rematch the pivot of the model and the turnable. in visualize
it looks like your Pivot is off a bit ,
try setting your pivot to the model and then recreating the turntable animation
thanks for ur screenshot yes this solve the issue
i have this same issue all the time, you have to set the model center to the XYZ center. its annoying that it doesnt show this until after the render
exactly in viewport it show correct ,, in the final render it shows the problem
