This content has been marked as final.
Show 7 replies
Re: model exceeds dimension limits solidworks
Fatih Mehmet Ozcan Mar 4, 2018 10:08 AM (in response to Tom Wielg)Can you post your file?
Tom Wielg Mar 4, 2018 10:17 AM (in response to Fatih Mehmet Ozcan)Thank you..
I attached it to the original post..
Fatih Mehmet Ozcan Mar 4, 2018 10:24 AM (in response to Tom Wielg)-
Tom Wielg Mar 4, 2018 10:28 AM (in response to Fatih Mehmet Ozcan)Thank you, worked..
Tom Wielg Mar 4, 2018 10:35 AM (in response to Fatih Mehmet Ozcan)-
Fatih Mehmet Ozcan Mar 4, 2018 10:53 AM (in response to Tom Wielg)Solidworks is not a good choice to work with stl files. You can't render because Sw don't see it as solid, try measuring it and you will see, it is not there in terms of Sw. If you want to do render stl, try Blender. You still need to modify some settings after importing your model, add a light source etc. to get a good result. I just saved it as Blender format and attached to this post
Also your stl file have some problems, it is not a closed geometry, you can fix this with Netfabb
elep.zip 3.6 MB
Chris Dordoni Mar 4, 2018 10:31 AM (in response to Tom Wielg)It is over 10,000 units in the largest dimension ... needs to be scaled to less than 10,000
