13 Replies Latest reply on Apr 19, 2018 11:03 AM by Jacob Corder
    Solidworks hangs in system WaitHandle after editing surface for macro feature
    Greg James
      Any tips for this problem?
      I'll send this to apisupport@solidworks.com
      A project for an addin to repro this issue is attached.  See README_repro_steps.txt
      The Macro Feature I've created is not doing anything, just returning from Edit(), Regenerate(), and Security().  Looks like the bug has something to do with changing the offset surface Feature that was selected when the Macro Feature was created.  Deleting the Macro Feature fixes things, in that the offset surface can be edited and updated without causing a hang.   Waiting for garbage collection in Regenerate() has no effect.
      -- bug description --
      An offset surface feature is selected when a C# macrofeature is created.
      If the offset surface feature is edited, or if an offset surface higher in the feature tree is edited,
      Solidworks hangs at the call stack below.  The hang occurs outside any addin code.
      Call stack:
      mscorlib.dll!System.Threading.WaitHandle.WaitAny(System.Threading.WaitHandle[] waitHandles, int millisecondsTimeout, bool exitContext) Line 454 C#
        System.dll!System.Net.TimerThread.ThreadProc() Line 707 C#
        mscorlib.dll!System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) Line 954 C#
        mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state, bool preserveSyncCtx) Line 902 C#
        mscorlib.dll!System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, object state) Line 891 C#
        mscorlib.dll!System.Threading.ThreadHelper.ThreadStart() Line 111 C#
      -- repro steps --
      Launch the adding by building and running from the visual studio .sln
      In Solidworks, open two_offset_surfaces.SLDPRT
      In the "C# Addin" command tab, select "Macrofeature PMP" to open the property manager page.
      Select Surface-Offset1 into the PMPage selection box.
      Hit "Create MacroFeature"
      Exit the PMPage by hitting the ok or cancel buttons.
      in the Feature Tree, select Surface-Offset1 > Edit Feature
      Modifty the offset distance and hit 'ok'.
      SolidWorks hangs.
      -- system details --
      Solidworks Premium 2016 x64 Edition
      SP 3.0
      Microsoft Visual Studio Professional 2013
      Version 12.0.40629.00 Update 5
      Microsoft .NET Framework
      Version 4.7.02556
        • Re: Solidworks hangs in system WaitHandle after editing surface for macro feature
          Jacob Corder
          So..
          the api help referencing the crash or hang on rebuild was my discovery.  it has to do with IDisplayDimensions being used.  if you aren't using IDisplayDimensions, then there is no need for you to call GC.Collect in your regeneration function.
          i am attempting to debug your application now.
          i dont see any code in the Regeneration method.  its literally empty.
          have you successfully created macrofeatures in the past?
              Greg James
              Hi Jacob - Thanks!
              Yes, for this repro I built a new simple project and took everything out of Regenerate().  Here, Regenerate() only prints a debug message and waits for the garbage collection.  My full fledged addin does a lot more, but that's not needed to repro the bug.
              One basic use for my addin and the macrofeature is to collect a group of surfaces.  Other code outside the macrofeature does work or writes stuff based on the collection.  In the past, I've used an Attribute for this.  It's a surprise that something about the selection set for the macro feature data causes a hang.
              I've created macrofeatures based on the api / sdk samples, and those are fine.  None of them have surfacebodies in the selection set though =/
              Jacob Corder
              ok. so this was kind of odd.
              i added a macrofeature, but it didnt ever communicate to the COMServer.
              so i added another.  at that point the first macrofeature had a serious playback error, but the ones i added after were all fine.  they didnt care if i edited the surfaces
              i however am not able to get the system to crash.
              trust me that means nothing when it comes to macrofeatures.
              the issue is that your comserver is not being found on the first macrofeature
              i am only seeing 3 regenerations being called to the comserver when rebuild is being called.
              Repro MacorFeature1 never rebuilds.
              there is something odd with the first feature created during the first session .  i have added
                    // Default constructor
                      public MyMacroFeature() {
                          Console.WriteLine("Macrofeature Instantiated");
              at the top so you can see when the COMServer is being created.
              it is being created when the first call to InsertMacroFeature3 is executed like normal.
              are you using DisplayDimensions in your macrofeatures?
              i am testing on 2018 SP1
              you will probably have to send me your actual code.  feel free to pm it to me.  trust me, when it comes to macrofeatures, i have 5 years of constant suffering associated with them.
              i wont be able to help much until monday.
                  Greg James
                  Wow - good find.  How did you discover this?  Some Visual Studio tool?
                  Code should be all there in the top folder out of the .zip.  My class derived from ISwComFeature is in MyMacroFeature.cs
                      [System.Runtime.InteropServices.ComVisibleAttribute(true)]
                      public class MyMacroFeature : ISwComFeature
                  It's declared like that, but I'm not doing anything to register the class, because I haven't found any docs that say I need to.... and because I'm not used to this COM / Windows registry business.  I figure that Solidworks would do what it needs to inside
                              IFeature lsFeature = fm.InsertMacroFeature3(
                                  "Repro MacroFeature",                                       // base name
                                  "sldw_hang_after_macrofeature_regenerate.MyMacroFeature",   // ProgId
                  to get the bits to the right place.
                      Jacob Corder
                      Ok so in the registry the class is registered in classroom clsid. The implementation of ISwComFeature must register the class because for years I never ensured that the registry was correct. If you add a key in local machine software solidworks solidworks xxxx macrofeatures it does use this to get the current version (we could care less about that btw)
                      In classroot clsid ( your guid) inprocserver you will have a few entries. One they points to the file location or your DLL.  If you put your comserver in the solidworks running directory or in the Global access cache GAC  it will find it there first.
                      I will find out monday why it might not be working.
                      Try this.  In .net you call createobject (comserver nAME)  it will create it.  Then the first macrofeature will probably work.
                      So when connecttosw is called
                      Add  createobject(yourcomservrname)
                      Also after you call createmacrofeature3
                      Get the macrofeaturedata and check if programid doesn't equal your comserver name. If it doesn't then set it to your comserver name.
                      The weirdest think is that normally you get an error in the feature after a failed rebuild.
                    Greg James
                    This also repros in Solidworks 2018 SP1.
                    Issue is being tracked as SPR 1072396.
                      Emerson Bottero
                      Could You Share a working example of Macro Feature? I'm really struggling here and I can't even make my property manager page show when editing a Macro Feature. I downloaded this but it never call a PMP on edit.
