Macro to Add Prefix to All Custom Properties
Question asked by Jonathan Westcott on Mar 2, 2018
Latest reply on Mar 2, 2018 by Jonathan Westcott
I've been looking to build a macro that prefixes ALL custom properties
The purpose of this is related to receiving data from external sources, not wanting to loose them immediately but also not wanting overwrite them when added to PDM (eventually I would like to get this to run as a task in PDM on a transition).
By prefixing them with say "IMPORT-" it will mean the original properties are still in the file but also that they could be easily removed later using another macro if required (by search for properties that contain "IMPORT-").
There seem to be a few macros that get close put aren't quite doing what I'm after.
I've taken and started to modify a macro by Keith Rice and got very close by just altering one line.
'Sort custom properites alphabetically
'Preconditions: part or assembly is open
'Written by Keith Rice
'CADSharp LLC
'www.cadsharp.com
Dim swCustPropMgr As SldWorks.CustomPropertyManager
Dim vCustPropNames As Variant
Dim vCustPropVals As Variant
Dim Current As New Collection
Dim Final As New Collection
Dim i As Integer
Dim blnFound As Boolean
    Set swModel = swApp.ActiveDoc
    Set swCustPropMgr = swModel.Extension.CustomPropertyManager(Empty)
    swCustPropMgr.GetAll vCustPropNames, Empty, vCustPropVals
    'Put custom properties in a collection
    For i = 0 To UBound(vCustPropNames)
        Current.Add vCustPropNames(i)
        Current.Add vCustPropVals(i)
    Next i
    'Insertion sort
    Set Final = Nothing
    Do While Current.Count <> 0
        'First cust prop
        If Final.Count = 0 Then
            Final.Add Current.Item(1)
            Final.Add Current.Item(2)
            Current.Remove 1
            Current.Remove 1
        'Find place in Final collection
        blnFound = False
        For i = 1 To Final.Count Step 2
            If UCase(Current.Item(1)) < UCase(Final.Item(i)) Then
                Final.Add Current.Item(1), , i
                Final.Add Current.Item(2), , , i
                Current.Remove 1
                Current.Remove 1
                blnFound = True
                Exit For
            ElseIf Current.Item(1) = Final.Item(i) Then
                blnFound = True
        Next i
        If blnFound = False Then
            Current.Remove 1
            Current.Remove 1
    Loop
    'Delete and re-add custom properties
        swCustPropMgr.Delete vCustPropNames(i)
    Next i
        swCustPropMgr.Add2 "IMPORT- " + Final.Item(i), swCustomInfoText, Final.Item(i + 1)
    Next i
This works fine when the number of properties is 0 or greater than 1, then it doesn't work.
The really isn't much need to sort the properties in this application but I keeps things neat as its so close to working it seems a shame not to continue with this one.
I can write a case to to skip when 0.
What I don't understand is what you can do with a Ubound of 1? Do I need to make a special case for the instance where there is 1 custom property or can't this be altered to accommodate it?
