How do you push data from the folder card to the file cards in PDM standard?
Question asked by Sara Allgeier on Mar 1, 2018
Latest reply on Mar 2, 2018 by Sara Allgeier
I use PDM Standard and I am having trouble getting the folder data card variables to push to the file card variables.  The folder card has the variable marked as a "text value". The file card uses the same variable name as what is used in the folder card. The "folder data card variable" and "default overwrites" boxes are checked in the file card.  When i try to use the "modify→update values" none of my files show up to be modified.
The variable i am trying to push is one i created myself.  I did not specify any attribute or block names in the "edit variable" window.
Any help would be greatly appreciated,
Thank!
