Convert SLDDRW to PDF Task failing
Question asked by Grant Kirkland on Feb 28, 2018
Our Convert SLDDRW to PDF Task which is built in to PDM 2018 is failing to overwrite or version existing files.
Task details show that a file was created and named successfully, but clearly it was not.
Has anyone encountered this?
EDIT:
I've narrowed it down to linking Revision in the file path. If I remove the file path link to the variable the existing file is overwritten correctly.
I applied the fix in S-053733 but nothing changed. Anyone have an idea of what's going on here?
A BUILT IN TASK SHOULD WORK. PERIOD.
