Hi all,
I already modified the calloutformat.txt file to suit our preferencies and it works pretty well for holes - we get exactly what we want. The problem arises on slots. It seems that is not possible customize slots callout; I would say the hole callout is not picking up the slots at all. Am I missing something?
I'm on SW2015; any improvement on this on future SW versions (2016-2017-2018)?
Any help is appreciated.
I tested this on SW2017 and the edit took:
The lower callout was created before the edit, the upper one after the edit (which was just copying the depth code):
Keep in mind, that "calloutformat.txt" is in a protected location, so be sure to move the file (to your Desktop for example) where it can be edited.
Other file format editors usually give you an indication the file is read-only in its regular location.
Note so with Notepad, so you can edit all you like, but if the file is in its regular location, no changes will be saved and you'll receive no notice of this.
So, perhaps, it's not an SW version issue, but a r/o file issue.
I hope this helps.
Cheers,
Kevin
