It pretty much is a double click now. You click, move the mouse
up a quarter inch to the "open part" icon and click again.
Hi Joel,
On your system it may be 1/4" on mine is at least 1.5" x at least
100 times a day =~ 150" unnecessary hand movement ... anyway, I'll
write a small plug-in to eliminate 150" here 100" there and so on
Hi Joel,
Mike
Mike D,
What version and SP of SW are you using?
Joel's solution is valid if you are on SW2008 and above. With
SW2008 new UI, unless you have turned it off, you get the Context
Sensitive pop-ups when you select items. One of those is Open and
you do not need to move the mouse miles to open a part.
Since you do not give us this info it is tough to help you with a
possible solution that may already be in SW.
Add info on your system and version of SW, like in my signature, to
your forum profile and you will get more appropriate responses
based on what version of SW you have installed.
On your system it may be 1/4" on mine is at least 1.5" x at least 100 times a day =~ 150" unnecessary hand movement ... anyway, I'll write a small plug-in to eliminate 150" here 100" there and so on
Mike
Joel's solution is valid if you are on SW2008 and above. With SW2008 new UI, unless you have turned it off, you get the Context Sensitive pop-ups when you select items. One of those is Open and you do not need to move the mouse miles to open a part.
Since you do not give us this info it is tough to help you with a possible solution that may already be in SW.
Add info on your system and version of SW, like in my signature, to your forum profile and you will get more appropriate responses based on what version of SW you have installed.
Cheers,
Edit: it would help if I actually attached the macro.
