I started several parts off of main part but now some of the finished parts are interlinked with the new parts that I am drawing and have a rebuild issue how can I brake the link between the parts and just have it to the original. Or just have it no link and rebuild issues for completed parts..
Thanks for your time. The new guy
Hi Jared,
If you go into the sketch > Display / Delete Relations, then you should be able to select "Dangling" in the drop down menu. This will show you all the relations that are causing the problem and you can amend / delete as you wish.
