Hello everyone. A major issue in the past has been linking custom properties and cut list properties but it seems SW 2018 has fixed this issue. In my sheet metal parts I can now simply copy and paste expressions from the cut list to the custom property tabs and the correct values are returned, so this is fantastic.
What I would like to be able to do now is create a part template for a sheet metal part that contains the thickness and the amount of bends within sheet <1> (I don't use multibody parts so I'm only interested in displaying sheet <1> properties.
I can achieve this if I have a part template with a base flange already extruded and cut list properties pasted over, but I would like to have a part template that doesn't contain any feature/sketch yet, so I can create a brand new base flange and they are automatically linked without me having to manually copy and paste over what I want. However the methods I've tried don't seem to work if you have them in place BEFORE the sheet metal flange is created, even if the expression is exactly the same (well it does actually work for sheet metal thickness, not the other values).
I could see this being achieved by having a macro that copies these values across AFTER a sheet metal feature has been created. Any suggestions would be greatly appreciated. Thanks!
Hi Kyle,
Your title and your description contradict each other. Wouldn't a fix mean you don't need a macro. The macro option has been around for a while. In fact SW cannot link cut list properties to c/cfg properties. Not easily that is. You can do workarounds, api etc. or model differently.
The whole limitation could be addressed easily in my opinion but so far I have only seen patch work over patch work over patch work.
No coherent working solution can be seen so far that would once and for all tie custom properties, configuration properties, cut list properties & BOM display seamlessly together.
Why SW can't figure this out even though the individual codes seem to be already existing beats me. Can't see the forest for the trees.
For over a decade (no bull 10+ years) we have been working around this issue with unfold-insert sketch with dimensions-fold workaround.
For decades SW has not been able to make this a feature. Instead they give us boundary dimensions for formed sheetmetal instead of flat layout dimensions in the formed state.
Unfortunately again another release without a fix
Elmar
