My PDM archive server is belly up, and as we have suppliers
cutting from our PDM service we are in a world of hurt until this
is fixed, any help is appreciated.
Sometime yesterday afternoon (I was out) PDM stopped accepting any connections. When I try to open the server from the Admin tool, it hangs for a bit then comes back with the message "The Archive Server connection receive operation timed out."
Also, when I try using the Archive Server Configuration tool to restart the service, the service completely hangs until I do a restart, then the same thing over again.
My VAR is working with SW on this but precious minutes are ticking away...
I verified that port 3030 is open.
EPDM 2009 SP2.0
Thanks in advance.
EPDM 2009 SP2.0
Thanks in advance.
We do have a web server setup but it's on the same physical server as the archive server.
The problem was this:
One of our remote replicated archive servers had turned Windows Firewall on, which was blocking port 3030 by default. Once I turned WF off, bingo, everything opened up and connections were up again.
So now my real problem is this (only since installing 2009):
Why does the whole system lock up when one replicated server goes down? Shouldn't the remaining servers carry on with or without the server which is blocking port 3030?
Chad
