Why is it that the spline handle hooked to the connection point will only move on one axis? I could've swore it moved before on more but now it doesn't.
Here's a video of whats taking place. I've done many searches and found nothing. I'm probably not using the correct terminology asking the question. Help would be much appreciated. Thank you.
check the relations on the spline. is it set to be on a plane? that would be one reason why it would be acting the way you describe.
