Is it possible to drive the length of a cylinder of a certain diameter from the volume of another part? I'm thinking about using an equation but how do I get the volume from a different model? That model is also split and I want it's total combined volume. I want the total volume of SPF1753-HS1 to drive the length of SPF1753-CO. See attached.
Message was edited by: Scott Giffin
I was unaware of why when I added a dimension to a custom property it always had the part name appended to the dimension name. It is exactly for a scenario you are describing.
Furthermore, this may be a candidate for a Master Sketch Part type model, where both of your parts are driven by a master part at the top of the feature tree. This Master Sketch Part can contain both the volume and the length, dependent on each other however you need, and then you use that part to drive your two parts. The benefit of doing it this way is that you eliminate a possible circular rebuild problem that you can run into by linking your parts together directly.
I'm sure if you posted your parts or some screenshots, you'd get more targeted help.
