In 2017 and earlier, we used a note and this macro: https://www.javelin-tech.com/blog/2013/05/link-solidworks-custom-property-to-note/#.WH0gz1UrKCg
to transfer the following properties to our BOM:
For weldment parts: $PRPWLD:"Description"x $PRPWLD:"LENGTH" LG.
For sheet metal parts: $PRPWLD:"Sheet Metal Thickness" X $PRPWLD:"Bounding Box Width" X $PRPWLD:"Bounding Box Length" LG.
Some of the properties aren't transfering to my notes in 2018, the note is just blank (the property is still in the note, but the value is passed). I can't figure out the problem. It's driving me crazy. I think it has to do with the new Linked Properties, but they aren't in the What's New Document so I can't figure them out either!
$PRPWLD:"Description" Works at first, then disapears after properties/parts are edited
$PRPWLD:"LENGTH" Seems to work all the time
$PRPWLD:"Sheet Metal Thickness" I haven't test yet Sheet Metal Properties still appear to be working
$PRPWLD:"Bounding Box Width" I haven't test yet Sheet Metal Properties still appear to be working
$PRPWLD:"Bounding Box Length" I haven't test yet Sheet Metal Properties still appear to be working
I need to start a case with my VAR, but yet again, SW has broken yet another workaround without fixing the root problem.
There were multiple threads in this years top 10 list voting that Deepak Gupta started for this issue. I can't find them now though. Deepak, any ideas?
Edit: Added a screen shot of my Weldment Custlist Property window.
Hit End twice when you open the template, because the macro feature won't load without the macro file.
You need to right click on Annotations > Display Annotations to show the note. It's hidden in the template.
Hi Rob,
I am currently experiencing a similar problem:
- Open SolidWorks 2018 (any SP)
- Create new Part document
- Create new sketch on face plane
- Create a line in this sketch
- Create a sweep function with circular profile to obtain a bar
- Add "Weldment" function to feature manager
- Edit the generated cutlist custom properties
- Add a custom property named "CUSTOM" with value "CUTLIST" and validate
- Edit the part document custom properties
- Add a custom property named "CUSTOM" with value "PART" and validate
- Save the part document
- Create a new drawing document
- Add a face view of the part into the sheet and validate
- Add an empty note attached to the bar and validate
- Right click on the empty note > Edit text in window
- Write : $PRPWLD:"CUSTOM"
Expected result : CUTLIST
Obtained result : PART
- Return to the part document
- Modify the name of the "CUSTOM" property to "CUSTOM2"
- Come back to the drawing document
Obtained result : CUTLIST
Conclusion: the weldment cutlist properties are overridden by the part document properties of the same name.
In your case, the cutlist properties which are not "transfered" to your notes are properties which exists (natively or not) in your part document properties.
Regards,
Alexandre
