Re: How do I change the default area hatch/fill for cross sections?
Glenn Schroeder Feb 22, 2018 11:54 AM (in response to Harley Widdowson)The System Options for hatch only apply when hatching is applied as a separate feature in Drawings. Cross sections default to reflect the Material applied in the model. You can alter the hatching some in the section view's Property Manager...
...or over ride the hatching by clicking directly on it and going to the hatch Property Manager (de-select "Material crosshatch" and choose whatever you want).
Glenn Schroeder Feb 23, 2018 9:30 AM (in response to Harley Widdowson)Harley Widdowson wrote:
Doesn't seem to affect it. It puts on this huge zig zag fill on every cross section i take, if i click the scale button it resizes the fill but I can't seem to remove it, which confuses the manufacturer.
Then you'll need to click on the hatching to get the Property Manager shown in my second screenshot. De-select the box for "Material crosshatch" and then you will be able to select "None" if you don't want any hatching at all.
Harley Widdowson Feb 23, 2018 9:46 AM (in response to Glenn Schroeder)Thanks that works to change it! But is there not a way to change the default cross section area hatch fill?
David Matula Feb 23, 2018 9:32 AM (in response to Harley Widdowson)if you have gone to the document properties and you are not getting the hatch to show up with the settings there. I guess that you have applied materials to the parts. That there will over ride the system options for the hatch. To fix this you would have to edit each material to be the kind of hatch that you are looking for.
Harley Widdowson Feb 23, 2018 9:46 AM (in response to David Matula)No materials applied to any part?
David Matula Feb 23, 2018 10:58 AM (in response to Harley Widdowson)report bug to var!!!!
