Selecting Edges
Question asked by Martin M. on Feb 21, 2018
Latest reply on Feb 21, 2018 by Jacob Corder
Hi all, I copied this function from a different thread and I'm trying to convert it to select edges instead of faces. Everything works except for the line " Set Edge = Body.GetEdge ". How do I get GetEdge to work? The link to the other forum https://forum.solidworks.com/thread/213089
    Dim AssyDoc As SldWorks.ModelDoc2
    Dim longstatus As Long
    Dim MyMate As Object
    Dim CompName As String
    Dim EdgeName As String
    Dim CCompName As String
    Dim EEdgeName As String
    Dim boolstatus As Boolean
    Dim myComp1 As Component2
    Dim myComp2 As Component2
    Dim SelMgr As Object
    Dim SelData As SldWorks.SelectData
    Dim Comp As Object
    Dim Body As Object
    Dim Edge As SldWorks.Edge
    Dim CurEdgeName As String
    Const swSelCOMPONENTS = 20
Public Sub SelectComponentEdgeByName(CompName As String, EdgeName As String)
    Set swModel = swApp.ActiveDoc
    Set SelMgr = swModel.SelectionManager()
    Set SelData = SelMgr.CreateSelectData
    Set Comp = swModel.GetComponentByName(CompName)
    Set Body = Comp.GetBody()
    If (Body Is Nothing) Then
        swApp.SendMsgToUser "Component Body Unavailable."
        swApp.SendMsgToUser "Make sure not lightweight or suppressed"
        Exit Sub
    Do While Not Edge Is Nothing
        CurEdgeName = swModel.GetEntityName(Edge)
        If (CurEdgeName = EdgeName) Then
            boolstatus = Edge.Select4(True, SelData)
            Exit Do
        Debug.Print CurEdgeName
        Set Edge = Edge.GetNextEdge
        Loop
