BOM in .slddrw does not update after Pack & Go...Why?
Question asked by James Harvey on Feb 20, 2018
Latest reply on Feb 28, 2018 by James Harvey
Problem Description:
    I use Pack & Go to copy existing drawings & assemblies into a new project. I initiate the P&G command from the drawing environment.
    After the project is Packed & Gone, I open the new drawing and use File>Find References to confirm that the drawing is referencing only the models I want referenced (also to see that referenced files are named & stored appropriately..).
    I then open several of the assembly & sub-assembly models to make the changes required of the new project. I typically "drill down" by opening the top level assembly from the drawing environment, and then open sub-assemblies from there so that things stay updated on all levels as I save and close the lower level sub-assemblies. The changes implemented have only to do with component quantities in the assemblies, top level, 2, 3, and occasionally 4 levels deep.
    So now I've made my changes and I'm back in the drawing environment and the BOM's that I have in my drawing will not update to show the correct quantities.
Any ideas why?
I have tried CTRL+B, CTRL+Q, saving, closing & re-opening the drawing etc. to no avail.
Does anybody know how to determine which model file a Solidworks drawing BOM is referencing? I haven't figured out how to find that..
I am aware that when I 'Replace Model' in a drawing view, the BOM reference does not change, but this is a Pack & Go. Why the discrepancy?
Another down side is that it makes me suspicious of every BOM in the drawing. If the Pack & Go source model gets revised I have to assume any associated BOM in this new drawing is going to change with it. So I'm replacing all the BOM's.
What I really want to know is:
1) Why does this happen with Pack & Go and is there a way to avoid it?
2) Why do the BOM references not show up on the list when I use File>Find References?
Any help or suggestions much appreciated!
Best,
James
Message was edited by: James Harvey
