Memory Issues
Question asked by Sean Donnelly on Feb 19, 2018
Latest reply on Feb 20, 2018 by Artem Taturevych
I have a part that seems to not release memory after my macro runs. I am creating a flat pattern for all of my sheet metal configurations. I've been deallocating the objects and can't figure this out. Any ideas? For basic models its not a big deal, but more complex models makes the memory jump up incredibly high.
Dim swApp               As SldWorks.SldWorks
Dim swModel             As SldWorks.ModelDoc2
Dim swModel2            As SldWorks.ModelDoc2
Dim swDraw              As SldWorks.DrawingDoc
Dim swFeature           As SldWorks.Feature
Dim swView              As SldWorks.View
Dim bSheetMetal         As Boolean
Dim iErrors             As Long
Dim sDrawingTemplate    As String
Sub CreateFlats(configs As collection)
    If swApp.GetDocumentCount() = 0 Then Exit Sub
    Set swModel = swApp.ActiveDoc
    If swModel.GetType() = 2 Then Exit Sub
    If swModel.GetType() = 3 Then Exit Sub
    sDrawingTemplate = swApp.GetUserPreferenceStringValue(swUserPreferenceStringValue_e.swDefaultTemplateDrawing)
    If sDrawingTemplate = "" Then
       MsgBox ("Error Retrieving Drawing Template")
       Exit Sub
    bSheetMetal = False
    Set swFeature = swModel.FirstFeature
    Do While Not swFeature Is Nothing
       If swFeature.GetTypeName2() = "SheetMetal" Then
          bSheetMetal = True
       Set swFeature = swFeature.GetNextFeature
    Loop
    If bSheetMetal = False Then
       MsgBox ("This Macro Is For Sheet Metal Parts Only")
       Exit Sub
    If configs.Count > 0 Then
        Set swModel2 = swApp.NewDocument(sDrawingTemplate, swDwgPaperSizes_e.swDwgPaperBsize, 0, 0)
        Dim config As Variant
        For Each config In configs
            Dim configName As String
            configName = config
            If SwFunctions.EndsWith(configName, "SM-FLAT-PATTERN") = False Then
                Set swDraw = swModel2
                'Biggest increase in memory
                Set swView = swDraw.CreateFlatPatternViewFromModelView3(swModel.GetPathName, configName, 0, 0, 0, False, False)
                Set swView = Nothing
                swModel.ForceRebuild3 (False)
                Set swModel = swApp.ActivateDoc3(swModel.GetPathName, False, swRebuildOnActivation_e.swUserDecision, iErrors)
            'Decreases memory by 40K
            UnsuppressFeaturesFlat configName
            configName = ""
        Next config
        config = Null
        Dim path As String
        path = swModel2.GetPathName
        Set swModel = Nothing
        Set swModel2 = Nothing
        swApp.QuitDoc (path)
    Else
        MsgBox "Please select at least 1 configuration"
Public Function UnsuppressFeaturesFlat(config As String)
    Dim feat As Object
    Dim res As Boolean
    Set swModelDocExt = swModel.Extension
    swModel.ShowConfiguration2 (config + "SM-FLAT-PATTERN")
    Set feat = swModel.FirstFeature
    Do While Not feat Is Nothing
        Let featureName = feat.Name
        If InStr(featureName, "Flat-Pattern") <> 0 Then
            Set swSubFeat = feat.GetFirstSubFeature
            While Not swSubFeat Is Nothing
                Let subFeatName = swSubFeat.Name
                If InStr(subFeatName, "Flatten-") <> 0 Then
                    res = swModelDocExt.SelectByID2(subFeatName, "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
                    res = swModel.EditUnsuppress2() ' Unsuppress the feature
                ElseIf InStr(subFeatName, "Bend-Line") <> 0 Then
                    res = swModelDocExt.SelectByID2(subFeatName, "SKETCH", 0, 0, 0, False, 0, Nothing, 0)
                Set swSubFeat = swSubFeat.GetNextSubFeature
            Wend
        Set feat = feat.GetNextFeature()
    Loop
    Set feat = Nothing
End Function
