Hello all together,
first at all, I am new in this forum and thanks for let me beeing here. Second: sry 4 my english if it doesn't pleases you. ;-)
I have a Problem starting SolidWorks 2017 through the API. I Have heard the experts are hiding in here. I hope you can help me troubleshooting this error and thanks 4 even reading until the end.
As a CAD-Manager I am trying to find corrupted assemblys regarding to missing file references ans corrupted mates. So i am writing an makro that starts SolidWorks and checks each assembly stored in a folderstructure. The Problems begins with starting SolidWorks. Because SolidWorks 2015 und 2017 coexists, the engine allways runs 2015 by default. So I checked the following solution, to descide which Version I want to run.
Unfortunately it didnt work well, so I decided to uninstall SolidWorks 2015. Now the Debugger gives back an exception, when running through
SldWorks app = new SldWorks();
Do you have an idea what can be the Problem.
Deep thanks 4 any help!!
Greetings
Patrick
Hi Artem,
Problem half solved. I dont know why SolidWorks is started by Default even when you have uninstalled this Version. But I do know now how to avoid this "default.behavior"- thanks of SolidWorks Support.
You have to start SolidWorks by the Activator.CreateInstance method: For example like this:
SldWorks app = (SldWorks)Activator.CreateInstance(Type.GetTypeFromProgID("SldWorks.Application.25")
25 stands for Version 2017.
Further codes:
for SW 2012
("SldWorks.Application.20")
for SW 2013
("SldWorks.Application.21")
for SW 2014
("SldWorks.Application.22")
for SW 2015
("SldWorks.Application.23")
for SW 2016
("SldWorks.Application.24")
for SW 2017
This also should work with CreateObject("SldWorks.Application.25")
Hope this helps everyone who has the same Problem.
Greetings
Patrick
