I'm not sure if this is possible. I have an imported .step that will only feature recognize so far. I have to draw the profile of the part. The OD of the part has an irregular tooth pattern that is absolutely painful to re-create manually (trust me). I would like to create a sketch to use in an extrusion of this profile. Is it possible to generate one? I would provide more info but some of this must be confidential.
SOLVED:
Created section view as a Solidworks drawing then exported to DWG and imported in model environment.
