Some of you may use Curved Monitor. Is there any added advantage over flat monitor when using SWX?
A flat monitor is how something would look in real life. If I have a pencil in front of me the sides are farther away than the center, just like how it would look on a flat monitor. A curved monitor the sides of the pencil would be the same distance as the center so it will look wrong on the curved monitor. Same for a curved part. A curved monitor is not how objects will look in real life, it is only good for landscapes.
https://www.youtube.com/watch?v=pDMwVGkNJPo
I suspect the curvature is far more subtle than what you are imagining.
,.. it's subjective.. but if you can get it on your desk,... a 34" @ 3440 x 1440 pixels!
LG 34UC80-B 34" (many variants @ > $ )
Acer XR342CK 34"
VIOTEK GN34C 34"
In my experience the curvature doesn't make much difference one way or the other, but it will definitely cost you more. Even if your company is paying for it, I'd distribute that extra money to larger size or higher resolution. Just be careful of getting too high a resolution on too small a monitor. For example, I wouldn't get a 4K 27" monitor. You will likely have trouble reading text. Also, take into account the resolution of your side monitors. If the dot pitch differs greatly between center and side monitors, it makes for an annoying multi-monitor experience. At home, I ended up with a center 32" monitor (2560x1440) and 2X portrait 24" monitors (1080p). This configuration results in the same dot pitch between center and side monitors.
I`m afraid that straight parts become curved .
So I use two flat monitors.
