3 Replies Latest reply on Feb 21, 2018 8:45 AM by Korbi Anis
    Create single face that combine a triangular reference surface
    Korbi Anis
      Hello friends, I have a surface that I create it using  some triangular reference surface as indicated in the picture .the problem that I cannot select the face diectly.I should always select all small triangular surface to select all the face.Are there a method to combine all these small triangular surface to get on surface .I tried to use Knit command but after get the surface I cannot use it to make a coincident mate for example with another face or part !! . someone can help me plzz.thank you
