TBTodd Blacksher16/02/2018
There have been a number of requests regarding my "All The Small Things" presentation from SWW18.
If you didn't get a booklet, I have attached a .pdf - If your printer will do 2-sided copies, everything should come out in order - just cut in half, fold, and staple.
If you weren't able to attend the session at , it was broadcast on Facebook Live, here is a link: https://www.facebook.com/solidworks/videos/10156056144344770/
This is a recording of the presentation from last year, if you are interested, here is a link: https://www.youtube.com/watch?v=OTOgRm9-L3Y
Update: ALL of the Facebook Live Videos from SWW18 are available here: On Demand | SOLIDWORKS WORLD 2018
EDIT: Files have been attached in the .zip file, they are as follows:
32 Ford - Shows "Combine-Intersection" and using Sketch Pictures. This one is a decade old, and I would do this a little different now.
bent-tube - Shows the Flex tool for "bending" tubing
benttubesm - Shows "tubing" made using Sheet Metal tools - will not flatten, because the last 3 features add material to "close the tube."
Combine - Shows "Combine-Subtract" - Quick and Dirty example built using same technique as part shown in the presentation.
HC 1014 - This is the .dwg file that was used to create the weldment profile.
ladder - Shows the Linear Pattern with the "Up to Reference" technique - Just select a side, click "Edit Part", click on the part and drag. (similar to room in presentation)
Press Brake - This is the amazing sample that ​ shared on the forum years ago.
TubAssy - This is the simple assembly that was used to animate the water draining from the tub.
Note: I believe that all files are in SOLIDWORKS 2018 format.
Update: I have not been able to track down any older version files, but I'm still looking.
Update: I did a small write up about the presentation for Engineers Rule, and it went up on the website this morning - Check it out:
https://www.engineersrule.com/small-things-cad-tips-tricks/
If you have any questions, this is a great place to start the conversation!
todd
