PDM Convert to 3D PDF template issue
Question asked by Elisabeth Daley on Feb 15, 2018
Latest reply on Apr 24, 2018 by Elisabeth Daley
I'm trying to use the new 3D pdf - MBD format in the PDM Convert task, and it's successfully creating a 3D pdf, but it's not using the template I specify (or any template at all).  I started trying to get it to use our custom templates, then backtracked to the default ones - neither works.  I've tried putting them in the vault (cached on the computer running the task) and also on the local computer running the task.  I did modify the script per the instructions here to enable the 3D pdf generation.
The path I entered for the default part template is this: C:\Program Files\SOLIDWORKS Corp\SOLIDWORKS\data\themes\simple part (a4, landscape)\
Should I be pointing directly to the theme.xml file (I tried that too), or something else?
