This content has been marked as final.
Show 4 replies
Re: SolidWorks crashes on import of STL file
Paul Salvador Feb 15, 2018 2:36 PM (in response to Mono Tovarisj)Hello Mono,.. from the error message, it is most likely beyond the 1km cube limitation of SW (parasolid).
so, in the import Options (for meshes) you would need to use another Unit to scale it down?
Otherwise, if you have access to another mesh based program, you would need to scale or reduce the facet quantity down.
Mono Tovarisj Feb 15, 2018 2:40 PM (in response to Paul Salvador)I don't seem to be able to find import options anywhere :-/
Paul Salvador Feb 15, 2018 2:42 PM (in response to Mono Tovarisj)-
Mono Tovarisj Feb 15, 2018 3:08 PM (in response to Paul Salvador)Alright got it down to mm and that worked, all though only as a surface model. However it still sucks that solidworks is stranded in a loop and isn't able to change it to a solid.
I really hate mesh files.
