Help with simple macros and keyboard shortcuts
Question asked by Patrick Dunleavy on Feb 15, 2018
Latest reply on Feb 15, 2018 by Patrick Dunleavy
I've created two macros. One to turn drawing items red and another to turn them black. I've assigned them the keyboard shortcuts of R and B, respectively. They work fine on everthing when I run them from the macro toolbar. When I use the keyboard shortcuts, they work for notes, datums, part lines (sides), and geometric tolerances so far, but they do not work with dimensions. I created the macros by selecting a dimension, hitting record, changing its color, pressing ESC, and then stopping the recording. Any idea why it only works for dimensions when run from the toolbar and not with the shortcut? Thanks for any help or pointers.
Both codes:
Red:
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Set swApp = _
Application.SldWorks
Set Part = swApp.ActiveDoc
Part.SetLineColor 255
Part.SetPickMode
Part.ClearSelection2 True
boolstatus = Part.ActivateSheet("Sheet1")
Black:
Dim swApp As Object
Dim Part As Object
Set swApp = _
Part.SetLineColor 0
Part.SetPickMode
