I am still working on a VERY simple part. However, It's killing me ( ). I've discovered another issue that may be causing some of my other head aches. The dimensions for extrusions are not showing.
Earlier I was trying to create a Global Variable. Everything I read said just to double click on the dim and then a dimension dialog box should appear where I could create my variable. However, there is no dimension to double click on. I managed to work around the problem by setting up the variable in the dimension field under the Boss-Extrude Property Manager, but I don't think that's the right way to do it.
No I want to go back and add tolerances to the dimension in the model so that it will automatically come into the respective drawings. See here: & https://forum.solidworks.com/message/794703?q=Extruside%20tolerance . But again, that dimension isn't isn't showing.
This is a quick screen grab of what my Extrude looks like with the dim not showing. The dimension for the base sketch is there, but not the extrusion distance
Is there some setting I need to change somewhere or a button to click?
I'm running 2018 SP 0.1
Thanks again
